two string inverter only shows reading for pv1 shows zero for pv 2 | on ElectriciansForums
Discuss two string inverter only shows reading for pv1 shows zero for pv 2 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
superk
tyneside
hi
i have a 4kw samil power solar river inverter.
when i log on it reading for pv1 shows zero for pv 2
i checked both strings with multimeter and both show simmilar readings.
just to note its like this even when im getting over 3kw
  • [ElectriciansForums.net] two string inverter only shows reading for pv1 shows zero for pv 2
it was a rainy cloudy day..i swapped the dc connectors over on the inverter still reads on pv1 nothing on pv2 so looks like both strings are working
Reply to two string inverter only shows reading for pv1 shows zero for pv 2 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
A searh of the manual for the inverter does not return any content for "ground". I do not find any pertinent reference in the table of contents.
