Two supplies in one room | on ElectriciansForums
Discuss Two supplies in one room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
stef
Gosport
Hi guys,
today I was asked 'just to look at it': The guy has a three bed semi, the small bedroom is some sort of an office. There is a ring mains (via 32 Amps) to one double socket outlet in the corner of the room without being used. On the oposite wall there are two double sockets connected as radial circuit fed from a 16A RCBO. Just above the CU is a combined line filter / surge protector , connected in line with the 16A radial circuit, for the computer equipment. This guy wanted two more double sockets connected to the radial circuit. The 16A RCBO is labelled up as office supply.
My question is: is it actually allowed to have two different supplies in one room? It may cause confusion when it comes to safe isolation.
I said to him that I hadn't much time today ...
Hiya. It's fine. There are not two supplies in the room, just two circuits from the same supply. 'Safe' isolation as opposed to isolation should confirm what is dead or what isn't before any work takes place - that's why the procedure exists.
Reply to Two supplies in one room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
