R
russells
Morning all, couple of things hopefully advice may be forthcoming on
1. A 16mm SWA will need to be made off into a Crabtree CU, The SWA is already in position coming from above, The way the (Plastic) Crabtree CU is moulded in the top section does not lend itself to glanding a SWA cable, its all very flimsy. question is what is the best way to adapt from 16mm SWA to possibly 2 16mm Tails, The armour is to be used for earthing so that would need to be adapted as well.
2. I live in a cottage type place with a few outbuildings etc, Its a reasonably secure place, however i want to build in a few tricks.
Basically when nobody is home overnight I want to have some INDOOR lights come on (say Landing and bathroom) by way of PIR from outside in the backyard (intruder would activate), but would also want the lights to act under normal switching when house is being used by occupants. does this sound possible without complicated switching etc??
Fed up of hearing stories where an outdoor flood only helps intruders see the booty, and feel if i was in an intruders shoes and some lights came on inside the house unbeknown to the fact the intruder set them off i would probably scarper quickly.
Opinions advice greatly appreciated
