Two timers to one load in parallel. and/or configuration. (NOT 3 way) | on ElectriciansForums
Discuss Two timers to one load in parallel. and/or configuration. (NOT 3 way) in the DIY Electrical Advice area at ElectriciansForums.net
gashmore
Macon, Ga
I have an air compressor plumbed throughout my shop feeding a dozen outlets. To avoid excess compressor running due to inevitable small leaks I installed a 120V solenoid on the compressor output. The solenoid is wired to a count down timer so when I need air I start the timer for one hour. At the far end of the shop is a hose spool used to inflate the tires. It gets used more than all the other outlets and I have to go to the other end of the building to start the timer any time I need it. To save steps I want to add a second timer at that end of the shop. The question is, can I (legally) wire both timers in parallel to the solenoid so that the solenoid will be on when either or both of the timers is active?
These are digital timers and I am assuming I will not let the smoke out if one sees voltage coming back on the controlled line.
Reply to Two timers to one load in parallel. and/or configuration. (NOT 3 way) in the DIY Electrical Advice area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
