Two water mains/ two bonds?? | on ElectriciansForums
Discuss Two water mains/ two bonds?? in the Australia area at ElectriciansForums.net
K
KNIPEX
Hi all.
im working in a small little building which has toilets/meeting rms/office kitchen etc, the water main comes in at the kitchen, ive pulled a cable in to bond this
however while in the toilets today i noticed another water main coming into the same building so it has 2, however i do not have a bond to this as ive only know just seen it.
this is a new one on me 2 water mains in the same small building, everything is cross bonded at the boilor now and if i cross bond in the toilets aswell will this be acceptable as the other water bond would therfore be cross bonded.
thanks in advance for your help.
oh no, thats pretty impossible now, just so strange that it has 2 water supplies coming in.
i can cross bond it, but getting a main bond to it is pretty much a nightmare.
anyone else got any ideas please?
Good call Jason.
In that case you could remove main bond and check continuity between the 2 incoming pipes.
If you have no or poor continuity then you would have to install second main bond.
Reply to Two water mains/ two bonds?? in the Australia area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
