Two way light switch with 2 cores! | on ElectriciansForums
Guest viewing is limited
Discuss Two way light switch with 2 cores! in the Lighting Forum area at ElectriciansForums.net
Europe
So i have a Ceiling Fan (lets just class it as a Light with a Pull cord at the light) and a light switch
Problem is i turn the light off at the Light at night .. and when i wake up i turn it on at the light switch.
Sadly the light switch is TWO Core so it doesnt really effect the light , ONE switch is on then the light is on, and other light switch will not turn off
So thinking of a Relay to change the 1P2T on-off switch in to a 1P2T on-on, not sure on what relay to use if i would have to drop the voltage down (making it even more complex) to send a signal to the relay via the LIGHT SWITCH.
also not looked in to the Light Switch at the Ceiling, just hope its a 1P2T on-on
[ElectriciansForums.net] Two way light switch with 2 cores!
Sorry for the Relay switch icon best i could do on this APP
It's not very clear what you're saying, so can you clarify:
You have a ceiling fan with an integral light.
It also has an integral (pull-cord?) switch to operate said light.
There is also a separate wall switch.
When either of the switches are in the closed position, the light will come on.
Both switches must be open to switch the light off.
You would like to change this switching arrangement so that it works as a proper 2-way switching arrangement.
Is any of the above correct?
Reply to Two way light switch with 2 cores! in the Lighting Forum area at ElectriciansForums.net
They are the same switch connected up differently.
Thanks again for your help, now solved 👍
