two way switch and extra light | on ElectriciansForums
Discuss two way switch and extra light in the Australia area at ElectriciansForums.net
G
geller
Hello
I have just moved to a new house and i have a large workshop at the bottom of my garden.
It has 1 strip light in it off of 1 light switch.
I want to add an extra strip light and add another switch at the opposite end of the room ( a 2 way circuit)
My question is, can i just link the 2nd strip light to the 1st with 1.5mm 2 core and earth.
Then link up the 2nd switch to the 1st switch with 3core and earth to make it 2way lighting ?
and is this job ok for me to do or should i get a qualified electrician in ?
Thank you.
Hi
yes you can just come off the first strip light and yeah just run a 3 core to the other switch, its pretty basic stuff !!!but all depends on how confident you are, if in any doubt give a spark a shout!! :)
I have a basic knowledge but wanted to be sure.
It seemed straight forward enough.
I don't mind doing it myself but wasn't sure if it was notifiable or not by an electrician.
Thanks guys
or he could just do the work save himself a hole lot of hassle and money
sometimes doing the right thing the right way just isnt worth the effort
He could do it himself he might even electricute himself, fall off the step ladder or fall through the loft. most accidents are caused by DIY "experts". Best to get an electrician:)
As it is notifyable, he would have to notify BC before the work commences, which would be a lot more expensive than just getting a registered spark in......!?!?!;)
since when is extending that lighting circuit Part P work? its not a NEW circuit nor is it in a special location. its non notifiable minor works and not under the scope of PP...its important that we are all singing off the same hymn sheet here!
its straight forward mate but save yourself a lot of agro and get a spark in
Well I havent agreed with much else The Truth has said but he is correct on this one, please see the link below.
http://www.the50plus.co.uk/tech_support/Part_P_Guide.pdf
Near the bottom somewhere
Reply to two way switch and extra light in the Australia area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
Did it work?
