Two way switching plus intermediate | on ElectriciansForums
Discuss Two way switching plus intermediate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
South east
Greetings.
I am pulling cables through a conduit system next door and have a question. The lights will be two way plus intermediate. I have attached a link to a diagram:
View attachment WiringDiagrams (1).pdf
The diagram picture number 3 shows "two wire switching plus intermediate two wire control", this would really help me.
It would be just right with the amount of space I have in my conduit.
However I wired a switch this way at college once and my lecturer said it was rubbish, no one would accept it and I must do it again wired as picture number 5 "two wire switching plus intermediate three wire control."
Is it OK to wire like picture 3 "Two-way switching plus intermediate 2 wire control" or is this a big No No.
I mean I can't see why not, if I haveto wire it as "three wire control" I would haveto terminate everything in the switch and really stuff the conduit with wires.
Comments would be appreciated.
Thanks.
the 2 wire method is absolutely fine mate, and i have wired a whole boiler in a power station that way.
The 3 wire method is better for domestic situations where you have no containment.
well for the 2 wore method to work, it will probably require a single switch wire from the switch, to the fitting. This will not be able to bhe incorporated into a cable unless you have spare cores.
Conduit, trunking etc
Well I have plenty of conduit.
I was thinking of using this job for my assessment, maybe the assessor will hate it.
There will be no spare cores, it is all wired in singles.
The three wire control must be for when we use T and E cable not singles.
It's a horses for courses ... 3 wire domestic (probably) two wire if your doing stuff involving conduit (coz it's cheaper to run the two singles).
Reply to Two way switching plus intermediate in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The old thread, that our friend hijacked, is here 2 dimmers on 2 way switching -...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
