Type of DNO supply question | on ElectriciansForums
Discuss Type of DNO supply question in the UK Electrical Forum area at ElectriciansForums.net
B
brenfox
I was installing a new control panel in a pumping station kiosk the other day. Sometimes I am required to `enter` the DNO supply to insert the earth cable on what is normally a TNCS system. To my surprise the supply was a single core with the armourings supplying the system earth but no neutral. Not sure what to think of this? Pretty sure this works fine in electrical theory but...
  • [ElectriciansForums.net] Type of DNO supply question
It will be concentric cable, associated with TNCS/ PME earthing.
The other type you may come across is split concentric, where you have the single core and two layers of conductor one normally unsleeved and the other sleeved over each conductor.
Reply to Type of DNO supply question in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
