Type of security head fixing | on ElectriciansForums
Discuss Type of security head fixing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
UK
I am looking for a tool to remove this type of security fixing (see images) does anyone know where this can be purchased from or the type of head the fixing is.
  • [ElectriciansForums.net] Type of security head fixing
Doesn't look much room to get a tool in there!
I wondered if this might do it 🤔 :
Available in M5 and M6
They're actually for screws like this, which are clearly not the same 😢
There are tri-head sockets available, but they need more space around the bolt than you have. I must be missing something 🤪
On that panel, are they metal screw heads, or plastic inserts?
I'll guess they're specific to teleAccess, a company which was wound up a few years ago.
Whether anyone has taken over their product range I know not.
What's the reason for wanting access, is the panel to be removed, if so use a cut off disc to cut a slot in the end of the screw?
Thanks for your reply, they are stainless.
Thanks for your reply, they appear to be stainless M6 type screw/pin.
Thanks for your reply: We need access the unit to terminate the replacement supply/load cable, I don't really want to replace the whole unit.
Reply to Type of security head fixing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
That should be what your looking for...
Hi all, I’m looking to expand my knowledge and learn more around this side of the electrical industry. I’m a commercial gold card electrician...
