Type of Switch | on ElectriciansForums
Discuss Type of Switch in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
graham123
as above really, is this a 60947-3, or is their fuses behind? Can you open these without turing them off?[ElectriciansForums.net] Type of Switch
No i dont think that is a 60947-3 :p A 60947-3 is main switch in a domestic consumer unit.
Sorry i was wrong i googled it and it seems it is a 60947-3
On some isolators like this you can open the switch by inserting a pi in the end of the handle
Look at the end of the hand, (the round end and see if there is a small hole (about 1mm or 2mm diameter)
If there is a small hole, this is where you'd insert the pin
Reply to Type of Switch in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks to everyone for all the info, I really do appreciate it. The good news is I eventually finished the job by fitting a surface mount backbox...
2 3
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
