telectrix
Mentor
does anyone know a way to re-vitalise 24v drill battery, a tip i've had is to briefly flash the terminals with an arc welder. bit reluctant to try this. new batt. is £150 any tips?
mine is ni-cad, so i'll try cpc. seen these repair kits on ebay but a bit dubious of the quality
Open out the battery pack and measure the voltage on each cell - they should be 1.2v to 1.3v - it is usually pretty obvious which ones are no longer working - use marker pen and put an X on them for later identification. No need to separate them, but work on each cell individually. Get a car battery and jump leads and give each dicky cell a two second zap of 12V then remeasure voltage on that cell. Be positive when applying the leads - it will fizzle a bit. I hold the negative lead on the negative end of the cell then put the positive lead on for 2 seconds then off on the positive end of the cell. Anything measured positive and it ought to charge ok. Just don't hold the leads on too long - any more than 3 seconds and they may become unstable. Bear in mind this does not always work, and I cannot vouch for the longevity of this fix. But it's worth a go if they are as expensive as you say.
Other wise you can replace the individual cells, but bear in mind the straps are usually welded into place during manufacture - you need to get a really good strong joint.
telectrix
Mentor
cheshire/staffordshire
United Kingdom
Electrical Engineer (Qualified)
Business Name
Telectrix
U/S Drill Battery?
Australia
telectrix,
ringer,
