Evening all,
Doing a bit of forward planning for an extension with possible electric ufh. i Have worked out room will need 25m2 split between 2 matts 15 and a 10. 150w per square meter matts. I work out as about 16.3 amps in total. Only one stat so a contractorwill have to be fitted.. if Someone could point me in right direction with wiring to include contractor I would be most grateful. Normally I would take supply froom Db to double pole switch to stat then join cold tails and probes. Cannot get my head round contactor tonight. Do I need separate supply’s for stat and contactor, or supply to contactor then to stat via fused spur.
Simple to many I expect . Obviously a 2nd stat negates this problem
