UFH Heatmiser to Grant Vortex combi help | on ElectriciansForums
Discuss UFH Heatmiser to Grant Vortex combi help in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
IRELAND
Hi I have a heatmiser uh4 wiring centre and a grant vortex combi condensing oil boiler, doing the heat and HW in a small cottage, the room stats, pump and actuators are ok, but I need a bit of help with the connections to the boiler please, the connections at the burner plug are –
1 - sw live CH
2 – sw live DHW
3, 4, 5, E, N, L
Am I right in thinking 3, 4, & 5 are permanent feed from load side of heating FCU along with the supply to the heatmiser.
1 – should be fed from LR which comes live when there is a call for heat and LS can be linked to take a feed from a live at any of the stats. But then where does 2 get power from ?
1 - sw live CH
2 – sw live DHW
3, 4, 5, E, N, L
It would hardly be as simple as taking a link from 5 to 2 in the burner plug would it ?
Reply to UFH Heatmiser to Grant Vortex combi help in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
