UFH mat in bathroom | on ElectriciansForums
Discuss UFH mat in bathroom in the UK Electrical Forum area at ElectriciansForums.net
SSE
Was at a job yesterday & whilst running cables for lighting in a side attic space I came across something I’ve not see before (not surprisingly). The couple had a new bathroom installed last year & by the looks of it whoever installed the underfloor heat mat, they never measured the UFH mat correctly for the size of the bathroom. So from what I can see what they’ve done is when they got to the last tiled part of floor they’ve drilled a hole in the floor & stuck the heat mat wire under the floor & run the heat wire free in the void for about 300mm into the attic space & then have fitted a thick length of ply to joists, ran the excess cable out on top of the ply & then fitted another bit of ply on top of this. Doesn’t seem safe to me, should I notify the customer? I’ve been reading heat mat cable in air is a no no.
Reply to UFH mat in bathroom in the UK Electrical Forum area at ElectriciansForums.net
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
Rather than covering the issue, find where the moisture is coming from and address from that end, is the outside ground level above the inside, is...
