UFH pump help please.... ?? | on ElectriciansForums
Discuss UFH pump help please.... ?? in the Central Heating Systems area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Guys
Just seeing if anyone can help please.
Does this pump come with plug in type/ pre flexed feed (hopefully that makes sense!) as cant see how to get inside to wire it up ?
Where its located have zero room and struggling to get in and see properly (thanks plumbers !)
Cheers Sy
[ElectriciansForums.net] UFH pump help please.... ??
Did they mean to fit it upside down too?
There’s an arrow on the rear view, meaning the way it’s orientated, water is being pumped FROM the manifold not INTO.
Am I right or wrong there?
Reply to UFH pump help please.... ?? in the Central Heating Systems area at ElectriciansForums.net
As per Davesparks, it would be helpful to see a picture of the valve etc. If the manifold valve referred to is a common or garden motorised...
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
