Hello all,
Im not an electrician, but please don't bite.
I am renovating a house, and receiving conflicting advice / quotes from electricians, and don't know which is correct, and so I'm looking for a bit of confirmation.
My plumber has installed the pipe work, and boiler. The UFH is yet to be laid.
The system description is:
Combi boiler (Baxi Duotec 40).
Downstairs UFH with 3 zones. I have purchased the kit from the underfloorheatingstore, and also purchased a UH4 HeatMiser wiring centre, manifold incl pump and actuators, and 4 x Heatmiser Neo thermostats.
Upstairs is radiator heating.
I have had 3 electricians round so far, and each suggesting a different layout.
1) Wire the rads thermostat straight to the 2 way valve on Radiator pipes.
2) Use 2 wiring centres, one for UFH, one for radiators?
3) Us the Heat Miser wiring centre for all.
I'm a bit confused, and have lost a bit of faith in the guys coming to the house, and so I'm coming to this board to try and get a clear idea of what is the ideal setup.
I've attached a picture of what I think is the best solution, but I'm not an electrician.
Thanks for any help.
