UKPN and Tri-rated cable | on ElectriciansForums
Discuss UKPN and Tri-rated cable in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
Nearly Esteemed
Kent
A Job that I've took over near to completion...between the 400A isolator and Lucy board it has Tri-rated cables installed. UKPN have refused to connect isolator to head due to it being Tri-rated. I wasn't on site today and wasn't made aware the connection was being made today but the chap from UKPN has said its needs replacing on the fact it's Tri-rated. Could any of you think of reasons why it wouldn't be acceptable?
Usually you abide to their rules,don't think I've seen tri rate cables connected to main head before,they usually stipulate solid cores.Interesting though,obviously for ease of connection to your equipment it's ideal,but looks a no no for network
The connection to the head from isolator is solid core but between isolator and Lucy board is Tri rated.
Done tri-rated loads of times and never once been refused once, can't see any reason why they don't want it even from the head to main switch... I too would be interested to see what they say are the reasons.
Reply to UKPN and Tri-rated cable in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
