Unable to bury SWA | Page 2 | on ElectriciansForums
Discuss Unable to bury SWA in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm installing a similar sort of set up this weekend.
Instead of installing a board in the shed I'm fitting a 13 amp switched fuse next to an outdoor weatherproof socket. Then from there running 2.5mm high tuff along the perimeter wall to the shed and 2 double sockets with another 13 amp switched fuse feeding a bulkhead light. 30m run clipped direct. Well within regs?
criticism?
What is wrong with using 2 core SWA? I always use it (having said that, very little on domestic) and always ensure it meets the minimum size laid out in the table. I can't see the problem?
Reply to Unable to bury SWA in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
