Unable to remove lever on Grohe basin mixer tap Discussion Thread | on ElectriciansForums
Discuss Unable to remove lever on Grohe basin mixer tap Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Unable to remove lever on Grohe basin mixer tap
Content of the thread: I’m trying to replace a cartridge on a Grohe mixer tap but I can’t get beyond second stage!
I have removed the grub screw,but cannot lift off the lever.I have applied some wd40 into the grub screw hole,..but the lever won’t budge.
is there any other method for removing the tap lever?…help needed.
[ElectriciansForums.net] Unable to remove lever on Grohe basin mixer tap Discussion Thread
I have an exploded diagram of the tap,so know how to proceed once lever is removed.
Unable to remove lever on Grohe basin mixer tap to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Unable to remove lever on Grohe basin mixer tap Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
E
Mixer Tap Cartridge change advise. Hi Our kitchen mixer tap is leaking around the bottom. Unsure where the leak is coming from but suspect/hope a...
Eejay
E
B
Mixer tap ring sheared during seal replacement - how remove In serious trouble here, was going to replace seals around base of mixer tap spout as...
Barnjet
B
