T
torrens75
Hi,
I dont want the answers, just wondered if any could check to see if im on the path whilst trying to understanding the questions below!!
1. List three materials which may be required forremedial work following the rewiring of domestic premises, with buried wiring and flush accessories.
Now im reading "remedial work" as in repairs to an existing installation, but then it says FOLLOWING a re-wire, so everything should be right?
2. Describe three work activities, related to thefabric of the building, which may be undertaken when installing steel conduitand trunking in a new brick and steel frame workshop.
This has thrown me, what "other" activities would you do if you were there to do just the containment?
3. State six stages of preparation required beforework can be safely carried out on an existing electrical installation.
Are they meaning permits to work, isolation, barriers, signs or am i reading the question wrong?
Ive done the other 13 questions, the above just done seem clear?
thanks
thanks
