J
Jelj360
Hi guys. Nice to be back on the forums! Might be a silly question but I've been out of the trade for a couple of years and I'm a bit rusty, so be gentle with me. I want to install low energy 230v Under Cabinet Lights in my kitchen. They are the individually switched type. I have three cabinets all on different walls. My plan is to wire each one directly to the lighting circuit, via a separate feed and switch line, so I can switch them all on/off at the main two gang switch as well as idividually ( the 2nd gang being for the main kitchen lights. Is this a safe and correct method and if so, when I buy the lights, should the come with the correct lead or do I run 1.5mm T&E down to them? Thanks in advance for your help :redface:
