Under counter lighting product/solution question | on ElectriciansForums
Discuss Under counter lighting product/solution question in the Lighting Forum area at ElectriciansForums.net
CWhiteOT
Ontario
Background: I would like to replace my wired, under cabinet lighting with dimmable LED under cabinet lighting. Can you suggest a product or solution to my problem of a 10" space
Details: Ideally, I would like a dimmable LED light that is hard wired to AC switch that turns on/off the other two (three in total) under counter lighting. The wiring and switch are in place.
Pictures: One picture shows the 10" space under cabinet and behind valence. Other picture shows wider angle of kitchen and the other two lights that are controlled by the single switch.
Is there a puck, in line or tape LED that can be hard wired? If not would a transformer work for some of the plug-in solutions that are out there? How might that work?
Thanks,
Chris[ElectriciansForums.net] Under counter lighting product/solution question[ElectriciansForums.net] Under counter lighting product/solution question
TL;DR
Is there an LED under cabinet lighting in 10" spot that is hard wired?
Reply to Under counter lighting product/solution question in the Lighting Forum area at ElectriciansForums.net
Neutral and live
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
