under cupboard lighting help | on ElectriciansForums
Discuss under cupboard lighting help in the Australia area at ElectriciansForums.net
C
ch657
hi i am at ajob and the customer has already fitted the under cupboar lights all of which are different which is somewhat annoying. i have brought the transformers for them and the are the correct rating. i just dont have a clue how to fit them. this is the first time i have ever had to fit transformers.
thanks.
Instructions with Transformers ? are they 1 light per transformer or several on 1.
If the lights are all different have you got the right wattage trannies for them ?
Gotta ask: If you don't know how to wire the Trannies, why take the job on ?
Reply to under cupboard lighting help in the Australia area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
Thank you so much for your help with this light work perfect now thank you again much appreciated
