M
madmatt
Hey chaps, I have just been asked by a regular client to look at fitting them some dimplex mat type under tile heating, thing is they have as far as i can see been intended to be powered via an rcd fused spur, taken off of an existing ring main socket spur cable. Anybody know if this is the kind of feed size needed or if an Rcbo would be needed at the consumer unit to cover the cct if I was to feed the system from an existing socket on a ring circuit ?
I have in the brochure only info regards the max mat size rated at 780 watts which is 3.39 Amps approx so do I take it that this is the only load I need to supply for ?? as in possibly power from a spur feed off a lighting cct or water heater supply ? Other nightmare is as far as cutting in a fastafix box for the rcd spur and programmer is that the walls are still covered in laughing plaster ( lathe & plaster ) which is always a pig ! if anyone has any tips please forward them ! The final thing is that the floor is only old battered up floor boards and it mentions the need to lay 18mm ply or tile backer board to provide a sound surface to lay the matting onto which by the time tiles are laid will surely raise the ffl sufficiently to make closing the door etc impossible ! lol... cheers for any help guys and or girls, Matt.
