Underfloor conduit for kitchen island unit? | on ElectriciansForums
Discuss Underfloor conduit for kitchen island unit? in the UK Electrical Forum area at ElectriciansForums.net
FatAlan
Trainee
Nearly Esteemed
Supporter
Surrey
Any recognised / best practice methods / conduit types for routing cables under floor. I’m looking to feed an island kitchen unit so will be looking to supply an induction hob and sockets.
Will be a completely new floor with insulation on top of concrete, underfloor heating pipes, screed with stone tiles on top.
Stick 25mm2 galv conduits in and put a draw wire in, however if the supply to the hob needs to be more than 6mm you will have to think again, PS, make sure the conduit is in one piece without any couplers and make sure any bends flow and are not tight.
As MDJ has suggested, last one I did I ran the 20mm2 conduit from a 100mm galvanised box so I could connect T&E to singles and also earth the containment. The other end went straight to a double socket but again a galv box could be used.
Presumably singles are easier to route through the conduit than T&E?
Reply to Underfloor conduit for kitchen island unit? in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
