underfloor connectors and access | on ElectriciansForums
Discuss underfloor connectors and access in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
Lindsayandson
I have been working on one of those jobs where the customer wants to add new outlets on a ring which is now largely behind new plaster which the builder is very protective of. we can connect under the floor to add new outlets, but the floor is going to be covered with a laminate. I guess that counts as inaccessible and I am wondering what are the acceptable options for making connections. Any help please.
Reply to underfloor connectors and access in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for that. This is essentially what I’ve done so far but not quite finished the job. I noticed the instructions are not lengthy but...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
