Hello,
New to the forums, I don't know if anyone is able to help me or give me some advice or tips (I'm not an electrician).
Me and my partner are buying a new build home and we wanted to fit underfloor heating downstairs, we have worked out it will be approx 15sqm of matting 100w matting, I believe this will mean wen it's on it will be consuming 1500 watts? My question is this, when we hire an electrician to connect it up, will he be able to simply be able to wire a switched spur from a double socket nearby or will a new ring need to be wired in? My partner is having nightmares that loads of holes will need to be made in our new walls if a new ring needs to be installed and our builder won't change what is set on the plans. I've counted 8 double sockets in total in the lounge / kitchen area but unsure if they are one separate rings (Not sure if this is relevant).
My 2nd questions, which I know is really hard to answer but I'll ask anyway, how much would I expect to pay to have an electrician come out and do the work (Fitting a switched spur from a double socket - if possible - and connecting the underfloor heating system to it?
Any other tips or things to look our for?
Thank You!
Thank You!
