Underfloor heating cabling | on ElectriciansForums
Discuss Underfloor heating cabling in the Australia area at ElectriciansForums.net
E
ericlejman
Hi, I'm presently building a new house. Im installing a water filled underfloor heating system. The system has 12 zones split into three manifolds, each zone has its own thermostat and actuator. I need to run cables before I put up plasterboard. Can anyone tell what type of cable I need and run from where to where?
Thanks in advance
Eric.:confused:
Realistically it's gonna depend on the system but you're most likely going to need to run threecore and earth throughout, linking all manifold control centres. They should individually open and close the zones as their stats call for heat but you'll also need a switchline back to the boiler, this will usually be a separate terminal within the panels.
Try to find out the manufacturer of the controls and ask them.
you would be best off runnin a 4 core to each stat unless you have picked your system and it says different..the newer digital stats need 4 cores the extra one being used fore a night saver mode..
this recently caught me out on a install.. the system wasnt fully decided on when i was first fixing. i thought a 3 core and earth would be enough as did the engineer.. my heart sank when the kit turned up..the fresh plaster had only dryed.. hammer time:rolleyes:
Reply to Underfloor heating cabling in the Australia area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
