L
louiek
Hi - is anyone familiar with the devimat underfloor heating system? The system is being used in a bathroom to heat tiles. The system uses a floor thermostat as well as a room thermostat. The controller is situated outside the bathroom. For some reason the floor is not heating up - this happened after the power was off for about an hour.
Have reset the system etc. and all seems ok but the floor is just not heating up. Although the thermostat is set to number 6, the controller keeps clicking off about every 2 minutes and reverting back to number 5.
Any thoughts on this? Could it be a faulty floor thermostat?
Sounds like a thermostat prob or maybe the sensor....
Give devi a ring and they might be able to fault find for you..
DEVI Electroheat Ltd.
Brickfields Business Park, Woolpit,
Bury St. Edmunds
Suffolk IP30 9QS
Tel: 0845 434 9991
Fax: 0845 434 9489
or email technical
Technical - [email protected]
Underfloor Heating (Devimat)
Australia
louiek,
louiek,
