Underfloor heating mats | on ElectriciansForums
Discuss Underfloor heating mats in the Australia area at ElectriciansForums.net
daiplayer
Hi all, been asked to quote for putting in underfloor heating, but have never done it before. Whats the ' standard way' of wiring them in ?
Have checked some online ones and they are around 300W , Ib of around 1.5 amp , so can fuse spur off ring ? or best dedicate circuit ?
Wattage prob larger with area ? so larger Ib ?
Many thanks all
EDIT : 200W/M sqaured. , so eg: 20m square = 4 kW , .... 17A , dedicate 2.5mm 20A mcb ?
Fitted a few of these. You need to make sure you get exactly the right size for the area as it can be hard to loose the excess.
I would always try and put them on a seperate circuit if you can.
Yes, the larger the area, the larger your design current.
Obviously you've seen you can get differerent wattage/sq m mats.
Used this company: Electric Underfloor Heating | Underfloor Heating Kits and Systems and no complaints.
300w sounds like a pretty small system, I think the last one I did was 650w and that wasn't big!
Edit: I got a fancy stat, the one with the Neon blue background - Absolute S**t of an accessory to fit, It fills a 47mm box and the teminals are on the underside of it. Just to make you aware!
i1v seen some of your posts before dai.....so whats up here?.....why not fuse it down ....of a ring (if thats whats available localy)......and if inside a bathroom etc......then FCU it outside the special location............
many thanks ! :)
The customer has told me he already bought the kit , ( haven seen it yet mind ) , but you know how it is when youve never done something before. lol, god bless this forum !!! :-D
Yeah id rather it have its own circiut, have they all got a floor probe then i take it ? ....when you did them did you advice the undermatts etc ?
''i1v seen some of your posts before dai.....so whats up here?.....why not fuse it down ....of a ring (if thats whats available localy)......and if inside a bathroom etc......then FCU it outside the special location............ ''
PMSL ! is that a dig :-/ lol
How soon after fitting is it going to be covered (tiled?)? If it's to be a while, I'd suggest a bit of latex floor levelling to protect the element (that'll mean you'll need to plug all the holes though ;)).
Reply to Underfloor heating mats in the Australia area at ElectriciansForums.net
