Underfloor heating off immerser circuit | on ElectriciansForums
Discuss Underfloor heating off immerser circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
polo1
Glasgow
EICR, electric under floor heating taken off 16 amp rcbo, 2.5mm T&E radial for the electric immerser (which is used), via a SFS. Would you code or comment?Regards
Thanks guys. I was considering simply a comment, as there is a fcu and it's only 160W/m2 in a small bathroom. Don't know why they didn't use the rfc which was just as accessible. I much prefer to keep the immerser radial dedicated unless the immerser is no longer in use.
Reply to Underfloor heating off immerser circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
Thanks all. Sounds like I hadn’t completely missed the point on what Part P needs at least. I’m not so much worried about a knock on the door as...
