B
bigmondy
Getting asked more and more to install and have never quoted.
Considering trying it out installing an undertile element in a new 1.7m x 1.5m wet-room I am working on where we have insulated under the floor surface - 18mm ply - with 100mm insulation blanket between the joists and polystyrene sheeting tacked to the underside of the joists ( just to be sure we layed aluminium foil underneath the 18mm ply). It will be well insulated and will be the only source of heat in the room.
I was wondering if there was a preference amongst the experts on the following:
1. Mat or cable (easier instal, more economical, less call-outs/faults etc)?
2. Manufacturer (I noted that members of the forum get a discount at a supplier - however are there other favourites)?
3. I will be tiling as well (I know) and wondered if a self levelling screed is advisable prior to laying adhesive and minimising air gaps?
4. Do you always complete the warranty card and do certain types have issues when taking the IR and continuity readings?
5. Am I right in saying it is there is a recomended (not sure if it's 100w) heating cable that is used over timber floors - is this because of heat loss?
6. Fixed fuse spur on 6mm supply will be from a low level cupboard next to the wetroom would there be an issue (apart from crouching inconvenience) in placing the stat beside it?
7. Ebay seem to have good deals available (tin hat on)?
8. Newbie - so be gentle with me?
Thanks Gents.
Thanks Gents.
