Hi everone
can anyone advise me on two things
I'm having underfloor heating fitted and want to run it on my economy 7
Has anyone managed to do this and how could you control the input?
What sort of electric metre could be used?
Bearing I. Mind it turns off during the day so won't have electric at night ?
Any advise please would be helpful
Hi everone
Interesting... so what's your thought process/logic in wanting economy 7 for underfloor heating ?
Well
I have storage heaters and they will be removed
They are so economic and the underfloor heating I think will run sort of the same.. I have a log burner for evening heat.. Just debating weather this would be the way forward as ecomy seven is seven times cheeper?
I haven't had it wired in yet.?
Assuming this Underfloor heating is electric.
Economy 7 reduced prices only apply overnight, underfloor heating is normally required during the daytime.
The only way I can see this working is if you have a floor layed above the heating that is made of very thick stone slabs to store the heat generated overnight and allow it into the room during the day.
Thanks for your messages
Yes I know when it's on..
I wondered if it would keep most of its heat during the day..?
I also have tiles underneath the tiles on top.. I have log burner for evening? Has anyone actually tried it?
Or Fitted an input metre??
And there used to be systems like that. I replaced one of them. It had a great big contactor that clunked in at midnight and work everybody up.
No it won't.
The heat will escape the floor as there is no barrier to keep it in.
You'd have to have a floor specifically designed to retain heat, but release it on demand, I doubt there is such a thing.
No it won't.
OK but have you tried it? No
I think I will just get it wired in and test it with a simple on off switch and see
How long it stays warm.. Also have a high wattage matting... If its stays warm until late afternoon I will be happy and it will cost next to nothing as economy seven is so cheap?
If it doesn't work then I can get it wired with normal supply and metre etc?
Please stop and have a rethink, or you'll waste your money. I have underfloor heating in my bathroom, tiled floor. It takes a good half hour to heat up and after an hour the floor is back to the ambient temperature.
Storage radiators have two features that a regular (even well insulated floor) does not have
1. A lot of thermal bricks, inside a closed box, that absorb the heat and store it
2. A heat output regulator at the top of the closed box so that all of the heat does not escape too quickly.
A big open floor justreleases all of any heat very quickly into the air.
Also, do look again at your expectation
economy seven is seven times cheeper?
Check what your energy supplier is quoting. It is nowhere near seven times cheaper!!
[automerge]1569926901[/automerge]
MORE!!. I just looked at EDF tariff information (for standard rate, other deals are a bit cheaper, but not much)
Their standard rate is 17.77p/ kWh
If you go for E7, they charge
Day rate - 20.52p per kWh Night rate - 11.07p per kWh
So not even half the price at night time..... time to have a rethink?
You seem to have found E7 tariff that I'm not aware of... you say it's 7 times cheaper than daytime ?? So I pay 14.8p/kWh at all times... which would imply that you've found an E7 tariff of about 2.1p/kWh ??
Yes basically
but it was fitted in 1996
I run my water heater at night on it as well ?
Don't think it will work with underfloor heating.. Needs a storage heater
better option would be to use wood burner to feed radiators. obviosly the wopd burner would need a back boiler. ( Scouser advice is that wood is free if you visit Travis Perkins at 2.00 a.m. ;););)
I came across something like this in a 1960s flat. Surprised to find that it was on night tariff, it heated up the whole floor slab and slowly released throughout the day. Original installation, still working 50 years on
Best solution would be to use a back boiler from the wood burning stove to heat a thermal store... then use the heat from the thermal store for a wet underfloor heating system and domestic hot water too ! That could be a very cheap system to run (TP permitting...)
Couple that with a PV array and battery storage system, sufficient to give about 8-10kWh in the winter... you could go off-grid !!
Gran had that setup in her sheltered flat. It was terrible, really really terrible.
Floors were hard because she could only have thin carpets, and temperature regulation was really really rubbish. Part of the problem was the south facing window - so on sunny afternoons the place would be roasting but still getting heat from the uncontrolled storage heater (aka floor slab). But that was only part of the problem - as mentioned, heat output is highest in the early hours when fully heated, and lowest in the evening (when you most want it) as the slab cools.
I have experienced a similar thing in an old flat. It was always too hot in the daytime.
I assume it is electric underfloor heating? ?
If so, there's little point having it on E7. The floor will heat up when you are asleep and then switch off just about when you wake up.
Yes we have e7 underfloor
stone oversite/100mm celotex / 100mm concrete/cable elements /50mm concrete /carpets
works very well room stat and contactor to control takes 2 days to heat up then stays constat all winter
cheaper running than our other house
Indeed, many years ago one of my grand mothers moved into a flat with electric off-peak underfloor heating. It was truly terrible.
The theory was that using off-peak it would heat up the big concrete slab, which would keep the flat warm all day.
In practice, it meant that the floor was hot first thing in the morning and the flat a bit over heated. After a while it would all start cooling down. If it was a sunny day, then the sun would stream in through the large front window and the place would overheat for the afternoon. If there was no sun then things would just keep cooling down. And then in the evening, it would be getting cool or cold.
And of course, this was back in the 70s (IIRC) so not insulated to modern standards, hence needing considerable heat input - and meaning that only thin carpets & no underlay could be used. Not very comfortable underfoot.
Thanks for your reply @gaz101 are you saying you keep the UFH on day and night on a room thermostat to keep the temp constant all winter rather than switch on and off daily? Thanks
It is wired from the e7 timer only heats at night
Sorry not sure I understand that question. I can set the time the water is heated on the economy 7 panel and the UFH has zones to which we can set the times and temps.we pay a cheaper rate for electric at night on economy 7 compared to daytime hours.
Did you test this out? I'm still unsure of the most economical way to operate my UFH with the economy 7 meter the builder installed. Be interested in your test results. Does the floor retain enough heat during the day from it being switched on at night when electric is at it's most cheapest? Thanks
Alot depends on how it's installed... i.e. do you have enough thermal mass to play with. Normal electric UFH is not designed to work this way.
A builder built my house, so I have no idea what thermal mass even is ?but you probably suspected that!) I have heard talk that UFH retains the heat well esp if you have good insulatio in the building. I'm hoping I can switch it on for a few hours at the cheap rate (as it takes a long time to warm) and it will retain a temperature comfortable enough to not need the an extra heater during the day/eve? ?‍♀️?‍♂️?‍♀️
Retaining heat and the type of heating source are different things. A well insulated building will retain heat regardless of where that heat came from.
Also, a big slab of concrete will indeed contain quite a bit of heat - but then the heat input to the room from that slab is uncontrolled. In some respects, the worst thing is a big heavy slab because it stores a lot of heat so it can't be turned down quickly. That's a problem with night storage heaters, because even though they have a damper to control air flow based on room temperature, to give the best results they need adjusting every day to suit expected heat demand for the following day - otherwise you either under-heat on cold days or over-heat on hot days.
Similarly, with a big heavy slab, yes you can store heat from off-peak lecky. But unless the room heat loss doesn't drop below the heat input rate from the slab to the room, then you'll end up with the room too hot. In practical terms you'll get more heat in the room in the morning (slab is hot), and less in the evening when it's typically most needed in a domestic environment because the slab will already have lost some of it's heat. Of course, a really massive slab will lose less temperature during the day for a given heat loss - but the flipside is that control operates over an even longer timescale.
As others have said, you may be better storing (at least some of your heat) in a wet system that can be easily controlled to output the heat where you want it when you want it. But that does need quite a large tank of water.
If you have rooms with a significant solar input (big windows, especially south facing) then you'll have serious over-heating problems (on sunny days) with a big slab of heated concrete.
If you have rooms with a significant solar input (big windows, especially south facing) then you'll have serious over-heating problems (on sunny days) with a big slab of thanks.
Yes, solar input is (often) welcome.
But not when you know you've spent a fortune on heating up that big slab of concrete and now have the windows open to get rid of the heat. And that's where any sort of uncontrolled (or poorly controlled) heat input fails - you end up with too much heat and end up throwing some of it away.
With controllable heating - e.g. traditional radiators or UFH without a huge thermal mass - you turn off the heat sources (or the controls do it automatically) when there's other heat coming in. But you can't do that when the controlled heat input was done yesterday - hence my comment that storage heaters really need adjusting every day for tomorrow's demands.
SO507PU
United Kingdom
Business Name
Ta desire
Underfloor heating with economy 7 ?
Electric Underfloor Heating Wiring
Lightbug,
Pretty Mouth,
