G
Guybrows
Hi all, I am 2nd fixing a job that someone else 1st fixed. I hav two wire coming out from under the tiles. One is a two core. One brown and one blue. The other is a bit bigger diameter cable and one core is blue and one is grey. As i did not install it i dont know which is the sensor and which is the load. I dont want to risk it as im afraid i will blow up the sensor if i get it wrong. Does anyone no a dead cert way of finding which is which. I thought about a resitance test but i dont have the instructions to check what they should be.
Many thanks for your help
