Underfloor Heating | on ElectriciansForums
Discuss Underfloor Heating in the UK Electrical Forum area at ElectriciansForums.net
London
Hi,
Now I understand that this question may seem pointless, so humour me anyway...
A lady had underfloor heating installed about 10 months ago along with her new kitchen...
I was there for the kitchen install but didn't do the mats, there are two mats serving her kitchen and utility room, both are connected to the same programmer....
after she had issues with 'overloading', as she was 'reliably' informed, the mats were disconnected...
anyway ive had a look and it is in fact a L-E fault on just one mat... so connected one back in and its all good with a reading of >999 from L+N-E
the other mat has a reading of 0.01 megohms and 17,000ohm for continuity from L+N-E....
she was sold a new programmer by the company as i passed this info on to the person who has taken responsibility for the install, and they called the technical support - who told him the readings are normal and that a new programmer at ÂŁ80 was required....
Anyway this mat trips the RCD obviously, but with a continuity of 17k if it was connected to just an MCB it would have a fault current of 13mA? and therefore the mat would work again?
yep fair enough, have called technical support and they will send a new replacement mat, but that cost is substantially outweighed by the labor cost of lifting and replacing all her nice expensive floor tiles... hey ho not my kitchen though!
na, nice thought though.. the 2 mats hit a jb before entering the programmer, i isolated the mat at the jb, so not the probe.... i agree with the tech bloke tho, its weird it worked fine for 6 months then one day POOF
They do - it doesnt take much to nik the cable then with the heating and cooling it just gives up. Plus some cable mats have very little insulation to protect them.
Reply to Underfloor Heating in the UK Electrical Forum area at ElectriciansForums.net
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
