underpinning knowledge questions... help please! | on ElectriciansForums
Discuss underpinning knowledge questions... help please! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Dan Spence
hi all, just need a bit of help doing the last few upk questions that need to be done before i can sit my am2.
Q1 what are the main requirements and procedures for inspecting and testing electrotechnical systems and installed equipment after fault rectification?
Q2 what are the organisational requirements with regard to informing relevant people about the test results and completing all relevant documentation?
Q3 what are the legal responsibilities for health and safety in accordance with current health and safety legislation, regulations and codes of practice?
Q4 where would you find out about principles of electrical theory and installation techniques for diagnosing and correcting faults in electrical systems and equipment?
they are the only 4 i have left, so any help would mean alot. many thanks
Q1, Think about what you need to comply with, and what you need to ensure when it is re energised.
Q2, I dont work in your organisation, but you do, so this should be easy to answer.
Q3, Have a look at the relevant regulations and acts, gov.uk website is very good for this.
Q4, There is a very large green publication, and a variety of guidance notes, that will give you all the info you require about this subject.
I am not going to spoon feed you the answers, so have a look, and then post your answers, you will get all the help you need if you have a go first.
Cheers.........Howard
Upvote 0
Reply to underpinning knowledge questions... help please! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
Electrical Courses
