understanding max current draw | on ElectriciansForums
Discuss understanding max current draw in the Australia area at ElectriciansForums.net
I
Inteificio
OK embarrassingly simple question.
One of the devices I have says the following:
"max current 13(2)A"
What does the 2 in bracket refer too?
Thanks,
I would guess it refers to the load being AC2 although I'm not sure why they have not used the brackets.
A load is rarely expressed without a qualification of how inductive or capacitive it is. You can have a contact that's rated to take a 13 amp linear load but it will only be capable of switching 6 amps of motor load. Here's a better explanation.
I've always taken it to mean 13A resistive, 2A inductive. I looked it up when I was a teenager and wanted to create some unusual circuit.....
Edit: I think it's something to do with the opening speed and/or separation of the contacts, and how they may draw an arc when opening an inductive circuit.
Simon.
I just had a thought,
Whenever I have seen this figure it has been on a relay; but specifically a relay designed to control heating elements.
Doesn't seem likely that they would put that on a controller designed specifically for a boiler...but in turn there is a lot of stuff that seems to defy logic in electrics.
Reply to understanding max current draw in the Australia area at ElectriciansForums.net
Thank you, Both are heat / cool only.
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
