Uneven roof.? | on ElectriciansForums
Discuss Uneven roof.? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Midlands
Well after loosing all my QMS and backup in January i haven't done anything about it, but i have a PV job to do, wooohooo
looks like ill have alot of back dating to do, only done three installs though so shouldnt take long.
Right my question
Basically im doing a 4Kw system and the house has had an extention, the extension roof is nice and straight but then dips about 2 to 3 inches to the old roof
Any good Brackets to use to compensate for the dip, ive only used K2 mounting system and you cant adjust the hieght.? tiles are Concerete pan tiles
Cheers
Grand
P.S the couple work for Windsor Life, owned by Swiss RE and they get ÂŁ2000.00 back from them, great idea, weather you buy a fridge, leccy car, solar, Heat recovery, you can get alot of money back for all green technologies :) .
We stock a few different types of anchor that have varying amounts of vertical adjustment.
If the roof is particularly bad and you want to keep the PV array level, we also have a plate adjuster that can be used to "extend" an anchor out to the required height.
Please get in touch if you would like details and prices etc.
schuco do an extension piece for their mounting kit that can extend it about 4 inches, but you have to be careful not to go more than 200mm above the roof surface at any point, which could be tricky.
Reply to Uneven roof.? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
