Unisulated Crimps | on ElectriciansForums
Discuss Unisulated Crimps in the Talk Electrician area at ElectriciansForums.net
G
GT1
Sorry, I know it's a basic question.
But I have to use some uninsulated crimps on some 16mm soon and I've never had to use them up to yet.
My question is about how to insulate the connection afterwards.
Heat shrink ?
Ah that's great. Was thinking that would do the trick. What is self setting tape ?? I've heard it mentioned. I think !
If it's the same as self amalgamating i think its tape that sort of melts and merges into itself when you wrap it, so it becomes a solid but flexible piece. That's a guess though I've never used it, they sell it everywhere though.
heat shrink or cold shrink, cold shrink dosent require a heat source (obviously) so probably a bit quicker
Heat shrink ?
Just a note mate. If the join your making is one that can't be accsessed for maintenance ie behind plaster make sure you use a compression crimper to do it :).
"sometimes called a helleman. you can buy special pliars to put them on with."
yes I know them pliers, but by a different name,don't want to be banned from this forum!
Reply to Unisulated Crimps in the Talk Electrician area at ElectriciansForums.net
Went into an MCCB, terminated very nicely thank you very much, however it was just me doing some training with crimping. 'introducing extra point...
Crimp or Wago inline connector, my preference would be Wago push fit...
