unprotected external cable | on ElectriciansForums
Discuss unprotected external cable in the Australia area at ElectriciansForums.net
M
martysparky
Called at a house today and noticed the outside light had Grey T&E clipped direct across the external wall.
I asked the home owner who installed the light.
Turned out it was arranged by Careline and a NICEIC guy upgraded the CCU (that seemed fine) and installed rear and front outside lights.
Could you share your thoughts on this please guys.
THANKS...
What do you guys use for external lights? I have been using hituf but it is very expensive and quite inflexible. SWA is cheaper and just as hard to work with but the added complication of earthing the armour.
Just seen some 'flextuff' (at least I think that is what it was. Same as hituff but more flexible and a little cheaper. Am thinkin of trying it next.
I'm with you lloyd on that it does look a sight!! Does not look professional either! Rather DIY in my opinion.
But I guess if thats what the customer wants it seems to be fine, However, if you did that in a Part P exam I'm sure you'd get the question wrong...
Thanks for all guys much appreciated.
When I'm testing if the T and E is showing signs of deterioration/perforation I give it a Code 1. If it is ok but is reasonably long run exposed to direct sunlight I give it a 2. I wouldn't personally install this way. I know this is a contencious issue in Sparky World, but that is my view! You pay cheap, you get cheap.
I agree that it looks cheap, and is probably not the best way to do it, but there's been some twin and earth clipped to my Dads fence for the last 30 odd years at knee level, feeding the shed (I know) and it still tests perfectly and is showing no sign of deterioration at all, even though it's been creosoted many times over.... I think it's more hard wearing than most people would believe.
Have a look at SY, its cheaper than hi tuf and loads more flexible, it has a plastic overcoat and then steel braid around the outside of the pvc outer core, The steel braid must be earthed but its easy to strip back and do. It satisfies protection against mechanical damage and sunlight.
Reply to unprotected external cable in the Australia area at ElectriciansForums.net
