Unsure about main bonding | Page 2 | on ElectriciansForums
Discuss Unsure about main bonding in the UK Electrical Forum area at ElectriciansForums.net
G
golfpaul
Hello.
Been asked to add bonding to gas, as British Gas has advised customer gas has no bonding.
[ElectriciansForums.net] Unsure about main bonding
Gas meter shows no signs of bonding, cannot see bonding to water either.
They have a shower cu which has a 10mm2 earth to it from the main earthing terminal - no other earth cables leave the MET which leads me to believe that neither gas or water are bonded...however:
With this 10mm2 from the shower connected to the MET, i get 0.00 to gas and 0.00 to water.
With the 10mm2 disconnected, i get a reading of 80v, and tester will not continue with continuity test.
There is a clamp of some sort near the stoptap, with bare cable running through the garage, where it appears to be broken in parts.
Does the gas and water need bonding, seeing as though i get a 0.00 with the shower cu 10mm2 connected to the MET.
And w
hy do i get 80v on shower cu 10mm2?
Ta.
Maybe just how I've read this, also can't see the pic too well but I'm wondering. ..
You say no other wires coming from met other than 10mm to shower cu?
Anything going to the main CU???
Most likely a meter reader or a BG worker touting for business!!!
My next door neighbour has just had his gas meter moved and they reconnected the bond to the new position, it was fitted that good that the clamp slid down the pipe and the cable dropped out. They had cut the cable as the meter was nearer the CU and in doing so the crimp was no more and they bodged the connection !!
can't knock weston's. the real ale version of cider. how come no alcohol? don't say doctor's orders. same doctors prescribed thalidomide.
Reply to Unsure about main bonding in the UK Electrical Forum area at ElectriciansForums.net
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
