Unswitched Power Socket Outlets | on ElectriciansForums
Discuss Unswitched Power Socket Outlets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DavidJ91
Can someone please clear this up for me:
Are unswitched socket outlets (power) still allowed to be used under the Regs. If yes, where and why? Is it ok when there's a fused spur attached...? I don't know.
Being told in college that they're not used anymore, but then I'm helping to fit them in new flats at the moment.
Confused. Need help.
Thanks.
Yes they're fine.
They seem to have fallen out of favour in recent years, probably partly because they're actually more expensive than switched sockets, so it's like you're getting less for more money.
Reply to Unswitched Power Socket Outlets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
Ah OK, that makes sense. Thank you Avo.
