Discuss unswitched socket outlets on a pir in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
i would advise customer that anything plugged in needs to be a plug top with the insulated sleeve on it so you can't get a shock! If nothing else it may get you extra work looking on the safety side of things
insulated sleeve????...... It's probably RWJ being dense again!! (Think I'm gonna quit to be honest!!! lol)
The old 13amp plug top of about 20 yrs ago never had half the LIVE/NEUTRAL pins insulated like the modern ones have, so you had all 3 pins of Brass,
In theory it was possible if the appliance was still on load, to get a shock by touching the bare brass of the pin, while it could technically still be in contact with the socket, when trying to un-plug, so since about the mid 90's most plugs have the insulated pins.
Right... With you.... That's what I thought he meant....
You mean the plugs the cheap "sticker merchant" PAT testers pass!!!
Actually there's no requirement to replace them, you just can't supply new equipment with them or retrofit them to old equipment.
Reply to unswitched socket outlets on a pir in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
