Doomed
Client wanted the flex for thier monitor routed up through tier desk, so I made a small hole for the flex and chopped the molded plug off to replace with a new one after treading the flex through the hole.
Then I look at the flex cable colours, cpc is purple, live is black and nuetral is white. Also the neutral is the only cable with a copper stranded core, the cpc and live are some dull silver metal.
Hmm, I think, not having this, off I goes and gets another flex (I have loads of 'kettle lead' flexs knocking about) and uses this one instead.
Never seen that colour scheme before, anyone got any ideas where it came from? The moulded plug had BS1363 stamped on it.
I did a pat test on a rock bands music stuff, one amp was wired to a 13a plug top with strange colours. So I failed do not use sticker, noted it, and they don't like me anymore. Oh well, am I supposed to check what conductor did what...they make the rules and I get slagged off for being fussy?
Don't suppose they will call me next year
just a warning (from experience), cutting off a moulded plug voids any guarantee
I think I would have argued that one assuming the connections were correct and the new plug top was not what caused the fault / failure
So if a plug top gets damaged and the colours are non harmonised then the item is scrap!!! in your book
I'm not surprised they won't call you
A lot of imported industrial equipment would never get connected if all the colours had to comply with the euro colour scheme
Doomed
Dorset
Unusual flex colours
Australia
Doomed,
chris gray,
