B
Benny_Boy
I just moved a 40A BS60898 from an RCD protected way to a spot just after the main isolator. ie not on the RCD.
..long story short...
The RCD which the breaker used to be on trips as soon as there's a load on the breaker! which is no longer on the rcd!! it's bloomin next to it on the other side.
I thought it might be some sort of weird proximity effect inducing currents in one side of the rcd as the mcb ws loaded up so I popped in a blank to make some room between the mcb and the rcd but still trips!
can anyone think of a reason why this might be happening?
any ideas appreciated
