Unvented Megaflo Strange Noise Hi,
I have an unvented megaflo that it or nearby components make these strange noises shortly after drawing hot water and then shutting off. In this example, water was drawn for 10 seconds and then shut off. The noise continued for around a minute. I couldn’t find where it was coming from and no pipes were vibrating.
The boiler was not heating water at the time.
I have an external EV as well as the internal baffle in my scenario. I believe the internal baffle is in the process (or already) has disintegrated given the white deposits in some of the tap filters.
Any ideas?
Thanks in advance...
Unvented Megaflo Strange Noise to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Any ideas?
