Upgrade kitchen scotland | on ElectriciansForums
Discuss Upgrade kitchen scotland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
higgie21
Hi Lads
I live up in Scotland, my friend is fitting a new kitchen, upgrading his cooker system to 45amp, the cable is 6mm
We were looking at putting the kitchen and dining room onto its own 30ampMcb as it a big house and the 30mcb is supplying the rest of the down stairs sockets, i know there are no reg’s to say that the kitchen should be on its own but with tumble dryers big fridge washing machine dishwater and not including toaster kettles etc it a lot
I know down in England you have Part p etc, but what is there up in Scotland?? We are happy to put the MCB in and upgrade the 45amp MCB putting the new ring in and test as per 17th,
Is there anything up here in Scotland that can stop, or to inform, i have in the past done work and had a spark in to check over, and test if needed
Open to the house
H
What electrical work is covered by the rules?
Any electrical work carried out under a building warrant. It is the responsibility of the person who orders the work (normally the person who owns the building), to find out if they need a building warrant. Your local authority will be able to give you advice about whether you need one for work you want to have done. However, it is likely that electrical work in new buildings, existing flats and in maisonettes and houses with more than two storeys, will have to meet the rules. You can get more information on this by visiting the Scottish Building Standard’s website at www.sbsa.gov.uk .
Who is responsible for making sure that new electrical work meets the rules of the building standards system in Scotland?
By law, homeowners and landlords have to be able to prove that all new electrical installations and any changes to existing electrical installations meet the rules. Your local authority has the power to force you to remove or alter work that does not meet the rules.
What should I do when I need electrical installation work carried out in my property?
There are two options. You can:
• employ an electrician that is registered with one of the government-approved scheme providers to carry out the work. These electricians are known as ‘registered installers’; or
• let your local authority check and approve the work when it has been done.
The Electrical Safety Council recommends that homeowners use a registered installer for all electrical installation work. See ‘How do I find a registered installer in Scotland’ for details of approved scheme operators.
The advantages of using a registered installer:
• The installer can deal with all the rules for you.
• The installer will provide you with certificates to confirm that the work they have carried out meets the rules and was carried out by a competent electrician (see ‘Does it matter who carries out electrical installation work in my property?’).
• You will get a refund on part of the fee for your building warrant.
• You will have access to a formal complaints procedure if the work doesn’t meet the rules.
How will I benefit from the new Building Standards system?
If you use a registered installer, you can expect to have safer, better-quality electrical installation work because they will work to the UK national standard BS 7671 (Requirements for Electrical Installations) and the Building (Scotland) Regulations 2004. When the work is finished you will be given certificates confirming that the installation meets these legal standards.
The certificates will be:
• a Certificate of Construction (Electrical Installations to BS 7671) that confirms that the installation meets the rules; and
• an Electrical Installation Certificate or Minor Works Certificate, that confirms that the installation meets BS 7671.
Yes. It is important that electrical installation work is only carried out by people who are competent. This means people who have the knowledge, skill and experience needed to avoid dangers electricity can cause them and others. It’s easy to make an electrical circuit work but it’s far harder to make the circuit work safely.
Safety for you in your home is very important. So, we strongly recommend that you use a registered installer to carry out any electrical installation work you need. Registered installers will always work to the UK national standard BS 7671 (Requirements for Electrical Installations), and will issue a safety certificate for their electrical work to confirm that the installation has been designed, built, inspected and tested in line with that standard. This includes making any changes to an existing installation.
Full details about the requirements of the new Scottish Building Standards can be found on the Scottish Building Standards (SBS) website www.sbsa.gov.uk
Reply to Upgrade kitchen scotland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You too? I thought I was in a unique position:anguished::coldsweat:
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
