Upgrading consumer unit! | on ElectriciansForums
Discuss Upgrading consumer unit! in the Talk Electrician area at ElectriciansForums.net
R
ryan24
Hi all..wondering if anyone could help me. i have an old wylex consumer unit and wish to upgrade it. the incomer fuse is 63A and the main switch on the board is 63amps.is it possible to install a new board with 100A main switch?
the 100A is the max. current capacity of the main switch. don't matter what the current drawn is as long as it's not more than 100A
and if it is and the DNO fuse dont POP!!!! welllll......
[ElectriciansForums.net] Upgrading consumer unit!
Reply to Upgrading consumer unit! in the Talk Electrician area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
462 excerpt below. The incoming supply is via a electrical plant room to the block of flat, each flat has a standard DNO cutout fuse but no...
