OP
Midwest, where you you at the start?Its a longer thread than it should be OP, grant you that. Reading your first post, that is a typical way of supplying a garage, albeit with a couple of slack things that could easily be rectified. So I think you'll be a hiding to nothing to suggest the original installer has done things incorrectly and should install new. I get the feeling, you had hoped we'd all agree that the builders of your property had installed the supply incorrectly, and you could gain some evidence for your cause to have an upgrade FOC?
As regards, your new additions, you can add as many sockets and lights as you want, the supply is limited by the 13amp fuse in your FCU in house, as been said countless times.
Unless you intend to run high load equipment in your garage, jig welders, hot tubs etc, I can't see it being a problem.
The 1.5mm swa cable has a ccc of 22A (Ref method D buried in ground/ducting), you could re supply that from the inside of your house, if limitation of 13A, is an issue for you? It seems you have been given various pieces of good advice, but not what you want to hear.
Why not get some quotations, and discuss with a competent electrician.
An answer like this is all that I really wanted.
I was looking for the builder to give me anything in the way of an upgrade.
You may find this hard to believe but I am a sparks, started life as a Mining Electrician many moons ago. Got my qualifications through college for a ONC & HNC in mining electrical engineering.
Certainly qualifies me to be called an Electrician.
Always been in the industrial environment, never done any domestic work other than my own and never done any 13th edition up to 17th edition as never needed.
I suspected all along that the SWA should be earthed, which its not but I'm not familiar with earthing regs as they stand now. I just wanted confirmation that it was either compliant or not so I can get the builder to correct it.
I did find it odd that they don't provide DP isolation for supplies leaving the building so again wanted to know if compliant or not so I could get it corrected.
After that I just wanted to make sure I wasn't doing anything wrong by fitting a CU in the garage. I fully understand fusing and discrimination so I thought dropping from a 13a to a 6 &10a was an upgrade giving discrimination at the garage CU.
Unfortunately far to many people seem to want to come down on you with their "I know what I'm on about" attitude and treat you like a pleb.
Lets be fair its a DIY section, why have it if they are just going to say get a competent electrician to check it out every time?
